Arcgis Online Open Data Et FeatureLayer multi couches
1044
06-26-2019 05:23 AM
AntoineRAJABALLY
Bonjour à tous,
Je dispose d'un feature layer possédant plusieurs couches (2 couches) dans  Arcgis Online.
Ce feature layer est partagé sur mon portail OpenData mais je me retrouve avec 3 entrées:
   - Une entrée avec le feature layer de base avec les 2 couches accessibles via un menu déroulant
   - Une entrée pour la couche 1
   - Une entrée pour la couche 2.
Est-ce qu'il existe un moyen de n'avoir, soit que le feature layer de base (ma priorité), soit chaque couche...
En vous remerciant d'avance.
Antoine
Feature service in AGOLFeature servie + Layers Opendata
I have a Feature Service with 2 layer in my base on Arcgis Online (because I want a WFS with all my layers).
When i share my Feature Service in the Opendata portal, the portal shows the Feature Service AND my 2 individual feature layers...
Is there an option to hide in a portal the two Features Layers OR the Feature Services ?
Antoine
Egge-Jan_Pollé
MVP Alum
Bonjour Antoine RAJABALLY,
I have had a quick look at your OpenData portal (Atmo Occitanie OpenData) and I managed to identify a FeatureServer with two layers on this portal (https://services9.arcgis.com/7Sr9Ek9c1QTKmbwr/ArcGIS/rest/services/fl_exp_occitanie_zas_2017/Feature...). So, I can see what you mean (see this page and /or screen capture below):
The data portal is showing both the Feature Service and the two individual Feature Layers.
Sorry, I don't have no experience with the configuration of OpenData portals, so I don't know whether there is an option to hide Feature Services or Feature Layers from the Content type list in a portal...
Cordialement,
Egge-Jan
