ArcGIS Online Map Viewer Forms - Ordering Domain Categories
1418
03-10-2023 01:21 PM
LJackson29
Hi -
I am new to Forms in the new map viewer. I have a hosted feature layer in ArcGIS Online published from Pro where I created domain values for a field. When I add the field to the form, the order of the fields is not the same as in the original domain, and are not logical (See snapshot). Is there anyway to reorder them into a logical order?
Tags (3)
RhettZufelt
MVP Notable Contributor
Go into the item details for the HFL, data tab, pick the layer you want, select the Fields button in upper right, click on the field that contains the domain, click Edit to the right of List of Values (Domain).
You can then move them to the order you want them to show in the Form.
R_
RhettZufelt
R_
LJackson29
Thanks!
