ArcGIS Online labeling problem with halos
3096
6
06-11-2019 01:14 PM
DanielSampson
Hi AGOL uses,
Has anyone had a problem with ArcGIS Online's labeling where when a halo is set, some of the labels display more "weakly" than others. In the example below, you can see that two of the labels aren't right. This happens regardless of font size, halo size, color, etc. The problem seems tied to specific features; all features are very boring all 2 pixel wide transect lines.
If I remove the halos, no problem but without them, many of labels got lost in the differently colored shore and water interface.
Advice? At least commiserate if you've seen this! Thanks.#
Problem with ArcGIS Online label display using halos
Katie_Clark
MVP Regular Contributor
Wow that's crazy, I JUST made a web map a few minutes ago and noticed this behavior for the first time. We were labeling contour lines. No idea what's causing it, but I'd love to find out!
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
DanielSampson
I'll let you if I can figure this out. Can you do the same if you crack the nut first? Thank!
DanielSampson
See the reply from Douglas Cochran.
RobinDiSalvo1
Being a new user to ArcGIS Online I did this yesterday and thought it was natural and didn't like how it looked on my map.  Glad to know it's not just me.  Hope this can be fixed or my map will be exported without labels and no one is going to understand my message.
DouglasCochran
This seems to be a known bug in Chrome, can you try another browser such as Firefox, IE, or Edge to see if the halo problem persists?
DanielSampson
That's it- the halos are bold and beautiful in Edge, IE, and Firefox. Thank you! Is there a fix for this in the works?
