ArcGIS Online Installation - Local Use
1395
10-10-2013 09:35 AM
PaulHuppé
Is it possible to install ArcGIS Online on our local servers instead of using the ESRI servers?  If so, what is required?  I assume we need ArcGIS Server, which we already have.  Unless you need a specific level of ArcGIS Server maybe.
paul
DerekLaw
Esri Esteemed Contributor
Hi Paul,
... Is it possible to install ArcGIS Online on our local servers instead of using the ESRI servers?
Yes, this is Portal for ArcGIS, an extension to ArcGIS for Server, and is included with ArcGIS for Server Advanced (both Workgroup and Enterprise).
You can also read about Portal in the help documentation.
Hope this helps,
BillHeigh
You can use local web services from your ArcGIS Server installation by registering your services with ArcGIS Online, as shown in this thread.
http://forums.arcgis.com/threads/92362-ESRI-Maps-Config-in-Excel-2013
DerekLaw
Hi Paul,
You can use local web services from your ArcGIS Server installation by registering your services with ArcGIS Online ..
To add onto Bill's post, there is a free Esri live training seminar on this topic,
Increase the Value of ArcGIS Services with ArcGIS Online
Hope this helps,
