ArcGIS Online Frequency Analysis
1881
02-09-2021 11:44 AM
kkoz490
Hello,
It there a frequency analysis tool in ArcGIS Online such as in ArcGIS Pro? I would like to create a frequency table within a web map that are based on three fields. This table would be used in a Dashboard to view errors of duplication inspections. I have looked for such a tool in the Analysis options in the web map, but do not see one.
I have a joined hosted feature layer view that is the result of relating culvert inspections with the culvert feature. I would like to perform a frequency from the joined view on culvert name, location, and inspection date. Any records from the analysis with a greater count than one would be an error.
How would I perform a frequency of this type in ArcGIS Online.
Thank you,
Kevin
DanPatterson
MVP Esteemed Contributor
The analysis tools Perform analysis—ArcGIS Online Help | Documentation
Don't see one
... sort of retired...
kkoz490
Hello,
Thank you for the link. I will read through it. Not sure what you mean by retired?
Laura
by MVP Regular Contributor
