ArcGIS Online - Calculate Roof Area?
3041
05-05-2011 01:34 AM
JohnSmith13
Is it possible to calculate roof areas using ArcGIS Online, or is this only possible using the Desktop version?
Thanks in advance.
MikeMinami
Esri Notable Contributor
the ArcGIS.com map viewer is not able to measure area...yet. It's something we're planning on including in the future. However, you can do this with ArcGIS Explorer online using the measure tool.
http://explorer.arcgis.com.
Mike
JohnSmith13
Thanks for the quick reponse Mike.
I will take a look into ArcGIS Explorer. Do you know if roof area calculations have been done before or if there is a similar example lying around?
I'm just wondering if something like this would have to be built from the ground up.
Regards
MikeMinami
I don't know. You might check out the samples in the API references. One site that I do know about is an application called Boston Solar. This app lets you click on a building to determine solar potential. I assume that behind the scenes, it must be doing some calculations. It's build with the ArcGIS API for Flex...
http://gis.cityofboston.gov/solarboston/
hope this helps,
Mike
DURGA_HARISHDAYAPULE
Hi Mike Minami,
        I am Durgaharish,  I want to know is there any tool available for calculating roof area using community maps of arcgis. I am wondering how solar boston built that  tool.  Please help me in this matter.
