arcgis.com time-enabled map
998
10-26-2011 11:09 AM
DaveBradway
I recently tried to make a time-enabled map.  I made sure the temporal data worked in ArcMap 10.  I exported the data into a .zip and uploaded it to my map on arcgis.com There isn't much help under the help topics for creating time enabled maps, but what I could find said I needed to go to the time-enabled layer on arcgis.com and click on description.  However, description is grayed out and unavailable.  Did I miss a step? None of the other layers I have uploaded have description as an available option either. How do I enable the layer description?
MikeMinami
Esri Notable Contributor
Time animation is not supported on uploaded data. It is only available if you have a service that has time information available.
Mike
