ArcCollector: Disconnect from WiFi while syncing - now won't sync
3737
06-10-2015 12:36 PM
EricDrummond1
Hello Russell Roberts,
I am running ArcCollector on iPhone 6+.  I'm pretty sure the problem I am having is similar to this bug here: BUG-000084156 - If network connections are interrupted prior to ex..
Basically, I came back from the field, tried to sync on WiFi, the connection was disrupted, and now I am receiving a "sync error" every time I try to sync.
Any ideas?
Thanks!
Tags (1)
MiaogengZhang
When you see sync error message, click More and you can see more details about the error. What do you see? You can also try http://blogs.esri.com/esri/supportcenter/2011/12/06/configuring-fiddler-to-capture-web-traffic-from-...pad-device/ to capture more details. It will help to know more about sync error.
