Arcade When Function Execution Error
4490
7
08-25-2021 08:37 AM
jfiacco
I'm working on a Pop-Up configuration using an Arcade expression to display related fields based on attributes in another field. I'm trying to use a When expression that states, when the well location field equals a particular string, display related fields, otherwise display nothing. There are multiple related fields associated with one well location.
I keep getting the following error:
I've tried various versions of my expression to get rid of the error but nothing seems to be working. Here are examples of what I have tried so far:
When(($feature.wellLocation == 'A3'), ($feature.A3ArapCycles) && (TextFormatting.NewLine) && ($feature.A3ArapFlow), None )
When(($feature.wellLocation == 'A3'), ($feature.A3ArapCycles && TextFormatting.NewLine && $feature.A3ArapFlow), None )
When(($feature.wellLocation == "A3"), ($feature.A3ArapCycles && TextFormatting.NewLine && $feature.A3ArapFlow), None )
When(($feature.wellLocation == "A3"), ($feature.A3ArapCycles || TextFormatting.NewLine || $feature.A3ArapFlow), None )
Could someone take a look and let me know if anything stands out? I've looked at a lot of documentation but can't seem to figure out why I'm getting this error. I'm relatively new to Arcade so any information/ideas would be greatly appreciated.
Thanks!!
Jenna
KenBuja
MVP Esteemed Contributor
To concatenate values, use "+"
When($feature.wellLocation == 'A3', $feature.A3ArapCycles + TextFormatting.NewLine + $feature.A3ArapFlow, 'None' )
jfiacco
Thanks, Ken.
That removed the error but it's still not recognizing the well location value so nothing is populated in the pop-up.
KenBuja
What are the possible values?
jfiacco
Here is a screenshot of the some of the attributes. I have over 700 fields. Each field has a prefix, in my form, indicating the specific well location. I only want to show the relevant fields for each well. So, for this well, I only want to show the attributes within the red box. I'm trying to figure out the correct expression/combination of expressions to parse down the attribute list based on the well location. Do you know of a LIKE statement or something similar that might work better than WHEN for this case?
KenBuja
You can use this type of syntax to get fields that have multiple prefixes
var test = "LAST";
return $feature[test + 'EDITOR']
 This is using one of the profiles in the Arcade playground
KenBuja
What you could do is something like this
var array = ['ArapCycles', 'ArapFlow'];
var output;
for (var i in array) {
output += $feature[$feature.wellLocation + array[i]] + TextFormatting.NewLine;
return output;
This is how it works in the Playground
jfiacco
Thanks Ken!
I ended up doing something similar. Instead of creating an array, I created a variable for each field associated with the various well houses and called them that way. It produced an output more along the lines of what I was looking for.
Example:
var RegencyArapFlow = $feature.RegencyArapFlow
var RegencyArapMeter = $feature.RegencyArapMeter
var RegencyArapLevel = $feature.RegencyArapLevel
var RegencyArapCycles = $feature.RegencyArapCycles
var RegencyButterfieldTankLevel = $feature.RegencyButterfieldTankLevel
var RegencyBradburyTankLevel = $feature.RegencyBradburyTankLevel
var RegencySysPressure = $feature.RegencySysPressure
var varRegency;
if ((!IsEmpty(RegencyArapFlow)) || (!IsEmpty(RegencyArapMeter)) || (!IsEmpty(RegencyArapLevel)) || (!IsEmpty(RegencyArapCycles)) || (!IsEmpty(RegencyButterfieldTankLevel)) || (!IsEmpty(RegencyBradburyTankLevel)) || (!IsEmpty(RegencySysPressure))){
varRegency += TextFormatting.NewLine +
"Arapahoe Flow: " + RegencyArapFlow + TextFormatting.NewLine +
"Arapahoe Totalizer: " + RegencyArapMeter + TextFormatting.NewLine +
"Arapahoe Level: " + RegencyArapLevel + TextFormatting.NewLine +
"Arapahoe Cycles: " + RegencyArapCycles + TextFormatting.NewLine +
"Butterfield Tank Level: " + RegencyButterfieldTankLevel + TextFormatting.NewLine +
"Bradbury Tank Level: " + RegencyBradburyTankLevel + TextFormatting.NewLine +
"System Pressure: " + RegencySysPressure + TextFormatting.NewLine
return varRegency
Thanks again for your help!
