Arcade not working in Pop-Up
5201
14
10-17-2023 07:40 AM
BrianBulla
Honored Contributor
The following Arcade expression seems to be working in the Expression builder, but after saving and adding to a pop-up nothing gets displayed.
Any ideas as to what might be going on??
BrianBulla
Honored Contributor
It's so weird that everything works in the expression builder but not in the actual webmap.  Have you ever heard of a firewall, McAfee or VPN causing issues with things like this?  I'm running out of ideas as to why this isn't working.
KenBuja
MVP Esteemed Contributor
I haven't, but I'm not running on Portal, so I don't know what bumps that adds.
BrianBulla
Honored Contributor
For what it's worth we are on Enterprise v10.8.1 and apparently REST services v 10.9.1
HannahWilson3
@BrianBulla - I know this thread is super old, but I'm having a similar issue. Did you ever find the solution or a workaround?
BrianBulla
Honored Contributor
Hi Hannah!  Unfortunately "No", I was never able to resolve this.  I guess my workaround was to stop using esri products, and started using VertiGIS.  Things seem to work a lot smoother there.
