Arcade Filter a featureSet
1883
04-18-2025 10:04 AM
JessicaHendricks444
We are working to visualize datasets for a Dashboard using a complex Arcade expression. However, we are stuck on the first Filter function of a featureSet. Can anyone offer suggestions??????
var quadTable = FeatureSetByPortalItem(portalUrl, itemId, 29, ["QuadInsp_GUID","FaunaPresent_MarshQuad"]);
var quadOysters = Filter(quadTable, "FaunaPresent_MarshQuad IN ('1')");
The "FaunaPresent_MarshQuad" field can have text values of "1", "1, 2", "1, 2, 3", etc. We want to find those records that have a "1" somewhere present in that field.
Many thanks!
Tags (3)
KenBuja
MVP Esteemed Contributor
You can have multiple LIKES, but you have to use "OR" not "||"
FaunaPResent_MarshQuad LIKE '%1%' OR FaunaPresent_MarshQuad LIKE '%2%'
MobiusSnake
MVP Regular Contributor
Assuming you only have single-digit numbers, I think this would work:
FaunaPresent_MarshQuad LIKE '%1%'
If you have two-digit values it's going to be trickier.
JessicaHendricks444
Ooh that does work. Is there a way to select multiple values in that statement? I.e., if we want all records with a "1" or a "2" in them?
Something like
FaunaPResent_MarshQuad LIKE '%1%' || FaunaPresent_MarshQuad LIKE '%2%'
Thanks so much!
KenBuja
JessicaHendricks444
Thank you both so much!!
