Arcade expression query
1779
08-06-2023 03:50 PM
TTtttTeee
Hi Community, I am new to Arcade expression and trying to configure pop-ups for a feature layer in a web map.
What I would like to configure is that pop-ups shows the names of point features located within the 1km distance from a selected line layer. I tried to configure this based on the example that I found in Esri community; however, it did not work for some reasons. I got an error - "Parse Error:Line 25: Unexpected end of input".  That would be much appreciated if anyone help me solve this.
Code that I used is below:
// create the 1km buffer
var buff = Buffer($feature, 1, 'kilometers')
// get intersecting points
var point_int = Intersects(buff, FeatureSetByName($map, 'Address_point - Residential Buildings'))
// loop through the returned points and populate an array
var address_list = []
for (var s in point_int) {
    // get distance
    var dist = Distance(s, $feature, 'kilometers')
    // push a formatted string to the address_list array
    Push(address_list, `${s['Incident Name']}: ${Text(dist, '#,###.0')} km away`)
// return a newline-delimited string from the array
return Concatenate(address_list, '\n')
Tags (3)
JohannesLindner
You haven't closed your for loop. Add a closing curly brace in line 16.
Also, in line 15 your field name has a space. Use the actual field name, not the alias.
Have a great day!
Johannes
JohannesLindner
Have a great day!
Johannes
