Arcade Expression - Inspection Date in Current Quarter of Year
3764
08-01-2022 08:42 AM
AshleyHayes2
Hello!
I am trying to figure out how to write an Arcade expression that will determine if an inspection date occurred within the current quarter of the year (Jan-Mar, Apr-Jun, Jul-Sep, Oct-Dec).  My sense is that I need to convert the current date to quarter and the inspection date to quarter and see if they match, but I am not sure of the details for how to set that up.  Anyone done this before or have suggestions?
Thanks!
Tags (3)
KenBuja
MVP Esteemed Contributor
Here's one way to do it
var theDate = Date();
var testDate = Date(2022,7,4);
var theMonth = Month(theDate); //note Month is zero-based (Jan = 0)
var theYear = Year(theDate);
var quarter;
when (theMonth < 3, quarter = 1,
      theMonth < 6, quarter = 2,
      theMonth < 9, quarter = 3,
      quarter = 4);
var testMonth = Month(testDate);
var testYear = Year(testDate);
var testquarter;
when (testMonth < 3, testquarter = 1,
      testMonth < 6, testquarter = 2,
      testMonth < 9, testquarter = 3,
      testquarter = 4);
var output = "In current quarter";
if (quarter != testquarter || theYear != testYear) output = "Not in current quarter";
return output;
KenBuja
var quarter;
      quarter = 4);
var testquarter;
      testquarter = 4);
return output;
jcarlson
There isn't a function to directly pull out the quarter, but you could make your own using the month number easily enough. Assuming you already have a way of pulling your inspection date figured out, the rest of it could look like this:
// return quarter for a given date
function Quarter(d){
    var month_num = Month(d)
    return When(
        month_num < 3, 1,
        month_num < 6, 2,
        month_num < 9, 3,
// get your inspection date; i'm using a prior date as a placeholder
var insp = Date(2022,7,13)
// get quarter and year for inspection
var i_qtr = Quarter(insp)
var i_yr = Year(insp)
Console(`Inspection occurred Q${i_qtr} of ${i_yr}.`)
// get current quarter and year
var curr_qtr = Quarter(Now())
var curr_yr = Year(Now())
// return True if inspection is in current year and quarter
i_qtr == curr_qtr && i_yr == curr_yr
 Using a placeholder of sometime last month, I get a true. Changing that to sometime in February, it switches to false.
Oh and here's the console output, just to show what that's doing:
- Josh Carlson
Kendall County GIS
AshleyHayes2
Worked great in my web map!  Now, is it possible to use or calculate that "current quarter" information in a Dashboard gauge or indicator?  Thanks!!
AshleyHayes2
It turns out that KenBuja's code needed a small change to the When functions.
var quarter = when (theMonth < 3, 1,
      theMonth < 6, 2,
      theMonth < 9, 3,
      theMonth < 12, 4,
      "Fail");
