Arcade expression for 6 years after effective date
1566
06-29-2022 03:45 PM
L77
I need help writing an expression to use in ArcGIS online in a hosted feature service for symbolizing forest practice application data.
This is what I need it to display:
 If (The effective date plus 6 years)= date before today,  Label & Symbol: "6 year moratorium has ended"
 If (The effective date plus 6 years)= date after today,  Label & Symbol: "Active Permit"
This is the dataset I am using:
https://www.arcgis.com/home/webmap/viewer.html?url=https%3A%2F%2Fgis.dnr.wa.gov%2Fsite2%2Frest%2Fser...
I started out writing this, but it isn't correct.
var startDate = $feature["EFFECTIVE_DT"];
var sixyears = DateAdd(startDate,6, 'years')
return sixyears;
JohannesLindner
You're almost there. The last step is to determine whether the date you calculated is before or after today:
return sixyears < Today()
This will return true for permits that passed the moratorium date, false for active permits.
Then you can change the legend labels:
And that's it.
Have a great day!
Johannes
SteveCole
Honored Contributor
Maybe try something like this before your DateAdd line? Maybe it's not treating the date as you expect it to be..
var recordDate = Date($feature.dateField)
JohannesLindner
And that's it.
Have a great day!
Johannes
L77
Thank you so much, I really appreciate the help!
