Arcade EVAL function - evaluate a string to retrieve field value
1002
08-08-2023 10:25 AM
KevinMayall
I'm looking for a way to construct a field name in Arcade and retrieve its value.  Say you have a hosted feature layer with an attribute field named after each day of the week.  I can construct the field name as "$feature.insertDayHere" but that is just a string that I need to evaluate to get the value.  Does Arcade have any kind of EVAL function?
html = '<html table header stuff>';
var daynames = ["Sunday","Monday","Tuesday","Wednesday","Thursday","Friday","Saturday"]
for (var d in daynames) {
  var fieldname = '$feature.' + d;
  html += '<tr>' + d + ': ' + fieldname + '</tr>';
Kevin
KenBuja
When using a variable as a field name, you have to use bracket notation to get the attribute of that field. You can also use template literals to construct your strings. And when looping through an array, the variable is just the index. You have to get the value of the array at that index.
    html += `<tr>${daynames[d]}: ${$feature[daynames[d]]}</tr>`;
KenBuja
