Arcade date filter
1138
10-30-2023 04:19 AM
Lee_Butler
Hi all,
I have two layers in may map:
  • A layer consisting of 10km grids
  • A layer for users to mark the location of insect traps placed in the field
I want to set up a count on the grid to show how many traps have been placed within that grid. I have tried the following Arcade but all I seem to get is errors.  Any idea on where I'm going wrong?
// Count all traps in grid square since 30/10/2023
var traps = FeatureSetById($map, "186ca9c0d27-layer-24")
var sql = "created_date >= '30/10/2023'"
var trapFilter = Filter(traps, sql)
var countTraps = Count(Intersects(trapFilter,$feature))
return countTraps
Thanks
jcarlson
Can you share what kind of error you're getting?
Also, the format of the datetime string is probably where things are going wrong. It will depend somewhat upon on the underlying database system, but try writing your datetime in the format 'YYYY-MM-DD hh:mm:ss' and see if that works better.
- Josh Carlson
Kendall County GIS
Lee_Butler
Hi @jcarlson
Thanks for the reply
If I write my expression like this:
var traps = Filter(FeatureSetById($map, "186ca9c0d27-layer-24"), 'created_date >= "2023-10-30 00:00:00"')
var countTraps = Count(Intersects(traps, $feature))
return countTraps
I get this error:
Test execution error: Expected ["] or [A-Za-z0-9_.\x80-￿] but "-" found.. Verify test data.
If I switch the quotation marks around
var traps = Filter(FeatureSetById($map, "186ca9c0d27-layer-24"), "created_date >= '2023-10-30 00:00:00'")
return countTraps
I get this error:
Test execution error: Unknown Error. Verify test data.
