Application to fill forms
1161
02-01-2023 12:38 AM
LMBaptista
I want to create in ArcGIS Online (or Portal) and other AGOL resources (dashboards, survey, etc.) an application where people fill some forms and the result will be presented in a dashboard.
Looks easy, but I can't find the best solution to fill the forms. Survey123 is the obvious option but it will be too extensive and with different permitions for different groups of questions.
I can also use an app to filter the users according to the permissions and use a different survey for each one (on the other end, the files will be different which will limit the use of Actions in the dashboard.
Anyone have any idea for a best solution?
Thank you all in advance
JayantaPoddar
Please check if the followng workflow works for you?
1. Create a Survey App using Survey123 (FAQ: Is it possible to create conditional questions in Survey123 Web Designer? )
2. Using the Survey_Result Feature layer, create a Webmap and followed by a Dashboard application. The filters based on attribute values can also be handled in the Dashboard settings.
Think Location
LMBaptista
Hi! Thanks for the reply.
That is the standard proceder which have two problems:
1- the survey results will be on feature layer and not on the Database
2 - some questions of the survey must have different permissions for different users.
I would like to have a webapp, but can't find widgets to input data, some kind of text/numeric fields. The webapp does not need a mão.
