"Change Symbols" function for imported GPX layers
1359
09-29-2011 08:25 AM
PaulStahlschmidt
I've found it useful to have the opportunity to upload .GPX files to Arc GIS Online. The pop-up feature has also been useful, and I've been able to edit this after saving. But I am having a problem with something else...
Initially, the "change symbols" feature works just like the pop-ups (which I can change later), but the ability to change colors and the appearance of the lines DISAPPEARS after saving the map.  Is there any way to do this after saving? Am I missing something? Is there a plan for this in a new version? Thanks for all the work on this great application.
-PS
MikeMinami
Esri Notable Contributor
You've encountered kind of an obscure bug... The solution is to make sure you sign in before you create your map. This one will also be included in the update to our website early next week.
Mike
