Allow to set default style in new map viewer
4333
14
05-11-2022 11:34 PM
Labels (2)
RistoÜlem
In Map Viewer classic there is an option to set default style for layers. For example if I overwrite the service with new styles I can set default style in Map Viewer Classic. Can't see this option in new map viewer.
RussRoberts
Esri Notable Contributor
Not sure I am following - new Map Viewer supports the styling layers. Do you mean save layer?
RistoÜlem
I mean this button in map viewer classic. Can I do that in new map viewer?
RussRoberts
Currently no immediate plans to expose this in Map Viewer. Are you returning to the renderer at the service level often after you styled a layer?
RistoÜlem
Well I would say enough often that I would start missing this functionality very fast when we plan to start using new map viewer. Currently we are using old map viewer, and I thought that I try to use the new one with one project due to the layer grouping functionality. Lets say you are setting up a map and after showing it to customer the customer wants some symbols to be changed. So instead of removing the layer and adding again and setting again popups and stuff you could just set default symbology.
RussRoberts
The symbols could still be changed in this above case. Are you saying the customer would want the symbols used at the service or you would still change the symbols after the reset to defaults?
RistoÜlem
Yes the symbols can be changes in the map viewer but the selection of symbols there is limited and I cant use custom symbols (at least not yet). I will change the symbols in the service and I want them to appear in the map viewer by setting default. currently when I overwrite the service with new symbols they wont't change automatically in the web map and there is no option to set default values which will pull the symbols from the service like in the classic version of map viewer.
RussRoberts
You can publish your own symbols to online for use as a web style and use them in Map Viewer.
RistoÜlem
Seems like annoying hack. What if I want to use the same service in different maps then i have to change manually the symbols in every map.
RussRoberts
That isn't a hack and a supported workflow for reusing symbol sets. Especially if you wanted to use symbols that are SVGs or have multiple symbol layers so they look good on high res screens and varying sizes with no blurring/distortion that you see with picture marker symbols. Uploading symbols is planned for later the year.
Save layer is coming in this upcoming release.
