AGOL Web Map Filter Not working since 2026 updates
693
03-16-2026 01:42 PM
mpowersAK
We have a web map that contains a layer with some depth, temperature, and date.  We've had the map in production for over a year without issue until the recent 2026 changes.  The web map layer was originally filtered on Depth is ####, AND Date in the last 1 days.  However, we noticed it was no longer displaying any of the points.  Last Thursday, two of us were trying everything but it just wouldn't work.  We could filter on the Depth, Or the Date and it worked fine.  The minute we used the AND to filter, it wouldn't work.  I eventually stumbled on where I could set the Depth filer to 'is less than' ### and that worked....until I checked it this morning and that is no longer working.
So, definitely something going on with the Filters.  Not sure what else we could try.  We've verified the data set has not changed and is up to date.  We've tried changing the position of the two filters.  No luck...
RussRoberts
Esri Notable Contributor
Are you able to share the map and layer and we can take a look at what could be happening. If it cant be shared publicly you can invite russell_jsapi into a group.
