I have a feature layer called map in AGOL. I want to change the symbology, so I open arcgis Pro and I open this map and overwrite it with new symbols.
I see that the feature layer in AGOL is updated correctly. Only the views of this feature layers aren't updated at all.
Why is this and how can I make sure the views are also updated as well ?
PS: The legend is also not updated of the view layer.
Hosted feature layer (above)
View of hosted feature layer (below)
One of the whole points of feature view layers is that you can set separate symbology for the same data set. Because of this, data updates in the attribute table will apply to both the hosted layer and the view, but symbology differences are maintained. For this reason, it makes sense that symbology change to the hosted layer would not automatically update the symbology of the view layer.
You can change the symbology directly in ArcGIS Online, or change it in the same way you did for the hosted feature layer in ArcGIS Pro.
So let's say I have a hosted feature layer with 10 views of it. And I want to change the symbols. If I want to see the updated symbols of all of them, I have to open each individual layer in arcgis pro and change the symbols ?
As far as I know, that's the way to do it without using code. (changing the symbology directly in ArcGIS Online under the visualization tab on the item details page, or by pulling the layer into ArcGIS Pro). However, to be able to change the symbology of multiple layers at once, you should be able to do that with python scripting. I found this page that might be able to get you in the right direction:
Perhaps someone else out there knows more than I do, but hopefully that gives you a start
Thank you for the link Katherine! It is a nice direction indeed for a possible solution.
I wish it was easier but we have to do with the tools AGOL has.
Does anyone know if this idea has been submitted in ArcGIS Ideas? If the process can be completed with python, I feel like it shouldn't be too hard to enable it as a setting when updating a view in ArcGIS Online or the Enterprise Portal.
I would LOVE to know if it has. I run into this issue consistently and sometimes it takes a huge chunk of time out of my work day to update symbology on every single view layer.
Hello Jamil
Not really trying to give an answer, but asking a question instead. When you said:
What you mean by that? You export a layer to local, change the symbology, then you overwrite the layer? Im asking because I also struggle with the symbology on AGOL maps.
