Polygon layer in a feature service suddenly became uneditabe
1102
5
03-11-2026 08:37 AM
HanliePetoors
I'm working with a hosted feature service in AGOL. It has three layers, one each for points, lines and polygons.
On Tuesday the polygon layer suddenly become uneditable, both attributes and geometry. The other two layers are still editable.
When I try to edit it in ArcGIS Pro, I get the message in the attached image. This is a red herring because no relationship classes are present in the data, and, on Monday it was working fine.
I downloaded the data and ran check geometry on all three feature classes. The polygon layer did have some errors, mostly self-intersections.
At the REST endpoint the updateFeatures and addFeatures operations for the polygon layer give the message 'This operation is not supported.'
What can I do to fix this so that the polygon layer becomes editable again?
I don't want to create a new service with a new item id - this service is used in many maps, apps and web tools.
Hanlie
Tags (1)
EmilyGeo
No problem. It would be helpful to see the layer in order to figure out what's going on. Please reach out to tech support for help troubleshooting.
EmilyGeo
Hi @HanliePetoors
It sounds like its not working as it should. Can you share a link to the layer or a map?
HanliePetoors
@EmilyGeo thanks for the reply.
Unfortunately the data belongs to a client who is not willing to share it publicly.
The search continues...
EmilyGeo
HanliePetoors
In case this helps anyone, switching off all editing and switching it back on again on the settings page resolved this issue.
EmilyGeo
Thanks for sharing @HanliePetoors I'm glad that you were able to get it working again 😊
