AGOL thinks service is secured
3552
8
06-18-2013 10:58 AM
MilesWacker
We have a public map service at:
http://app.mdt.mt.gov/arcgis/rest/services/RIM/MDT_BOUNDARIES_931/MapServer
When this is added to My Content as an "ArcGIS Server web service" we get a message:
"A secure service was detected."
And it asks for a user and password.  This is not a secured service.  Is this a bug or something in our proxy setup?
MikeMinami
Esri Notable Contributor
I can reproduce the problem. We'll need to look at it.
Note, you can add this directly to a web map from the Add menu option when viewing the map.
Mike
MilesWacker
I entered a support incident for this.
Thanks
MikeMinami
The problem appears to be on your side. Perhaps your web server is set up to block programmatic access to the server?  ArcGIS Online sends this request to your server to gather information.
http://www.arcgis.com/sharing/checkUrl.jsp?url=http%3A//app.mdt.mt.gov/arcgis/rest/services/RIM/MDT_...
The response from the server is:
{"secured": true,"httpStatusCode": 403,"httpStatusMessage": "HTTP/1.1 403 Forbidden","httpResponse": "","url": "http://app.mdt.mt.gov/arcgis/rest/services/RIM/MDT_BOUNDARIES_931/MapServer?f=json"}
When the URL to the service is entered directly in the web browser, it works fine.
Mike
MilesWacker
Then why does this return fine:
That error is generated by the .jsp page, not our rest service.
How would you "Block programmatic access"?
MikeMinami
You are correct. The problem is on our side. We're looking at it.
Mike
MilesWacker
Anything here?
MikeMinami
Actually, we did debug this and found that your server is returning a 403 forbidden message when we attempt to connect from our API. Our developers asserted that there could be some rule set up on your web server that prohibits connections like this. From the browser, the connection is allowed.  Perhaps you can investigate how your web server is configured with this regard.
We have made a change on our side to ignore this error in this case. It will be released in December.
Mike
MilesWacker
Our proxy was blocking Jakarta user-agents.
