AGOL Feature Service as GeoJSON and Transformation?
434
04-30-2020 05:42 AM
MalcolmMeyer2
When I query an AGOL Feature Service with a projection not in WGS84 (NAD 83 in this instance) as GeoJSON, has the resulting file been transformed to WGS84, or are the coordinates simply representing the original file projection just in decimal degrees?
"spatialReference": {   "wkid": 102723,   "latestWkid": 3735 }
Same question goes for when this file is added to an AGOL map (WGS84). In this instance I believe the file is transformed to WGS84 with the default transformation from the map when it was uploaded. Is this correct?
Tags (1)
