AGOL Custom Expression Error after Update
1501
04-12-2018 12:12 PM
KyleBalke__GISP
The custom expression builder has stopped working when attempting to create labels in an ArcGIS Online web map.  Globals do not show in the list and when attempting to create an expression an "Execution Error:Cannot read property 'root' of null" is returned.
I cannot edit a custom expression that was previously created and I cannot create a new custom expression.
FYI, this feature was working without issue prior to today's update.
Kelly Gerrow
mminami-esristaff
KellyGerrow
Esri Alum
Thanks Kyle,
This is a bug that will be fixed tonight in ArcGIS Online. Someone from the support team will reach out to you.
-Kelly
KellyGerrow
Esri Alum
Thanks for reporting the issue Kyle,
We'll take a look at this but may have some additional questions about your environment. Would you be able to create a support case so that this can be tracked?
-Kelly
KyleBalke__GISP
Thanks...and yes please on the support case.
KellyGerrow
Esri Alum
Thanks Kyle,
-Kelly
KyleBalke__GISP
Kelly,
I appreciate the quick response and fix!
Best
