I implemented a Search Widget in an AGOL Web Application. The data source is a feature layer (polylines) contained in a map service in the associated Web Map. The field I am searching is a text field containing the alphanumeric pipe ID of the associated storm drain pipe (e.g. 10P10066). When I enter the pipe ID and select a pipe ID from the pull-down list (see attached) AGOL returns an error message "No Results Found...". However, when I copy/paste that exact Pipe ID into the Search input box and select search icon AGOL finds the pipe. Why do I get a "No Results Found" error message when selecting that exact same pipe from the pull-down list? This is very useful functionality that I would like to work and not have to direct users to key-in entire name rather than select pipe from pull-down list.
Any assistance is greatly appreciated!
Thanks much,
Steve Branson
FDOT D7 GIS Coordinator
I found a solution to my problem at least. Instead of referencing the feature layer to be searched as one from the map, instead I specified it from our larger Portal. After that the search worked again.
Hi all,
This issue may happen if you are using Alternate names or if you choose a feature service created from an SQL database view as the search source for the widget. To workaround this issue, you may try any of the followings:
All the best,
MJ
