Advanced formatting using Arcade in Dashboards
1349
04-02-2023 01:37 PM
AurelienJOSSET
Good morning,
I am trying to display in Dahboard via an indicator widget the sum of the Length shape of a layer by filtering such that the frequency is different from 0.
With the help of the community here is the expression:
var filter = Filter($layer, 'FREQ_MAINTENANCE <> 0');
var Sum = Sum(filter, 'Shape__Length');
return Sum;
However Dashboard with the advanced format, I'm forced to use $datapoint and I don't really see how to get out of it.
Which formula to put before the return
return {
  //textColor:'',
  //backgroundColor:'',
  //topText: '',
  //topTextColor: '',
  //topTextOutlineColor: '',
  //topTextMaxSize: 'medium',
  middleText: $datapoint.sum_Shape__Length,
  middleTextColor: '',
  middleTextOutlineColor: '',
  middleTextMaxSize: 'large',
  //bottomText: '',
  //bottomTextColor: '',
  //bottomTextOutlineColor: '',
  //bottomTextMaxSize: 'medium',
  //iconName:'',
  //iconAlign:'left',
  //iconColor:'',
  //iconOutlineColor:'',
  //noValue:false,
  //attributes: {
    // attribute1: '',
    // attribute2: ''
After several reading of document, I did not succeed.
Also what is the difference between: $datapoint.field AND $datapoint.["field"]
Thanks for your help
JoshuaSharp-Heward
Hi Aurelian,
Unless I'm misunderstanding I think you might be over-complicating things. When adding the indicator widget you're able to add a filter (in this case FREQ_MAINTENANCE not equal 0) and choose the statistic as "SUM" on "Shape_Length".
Cheers,
Josh
AurelienJOSSET
Hi Josh.
My return is late, sorry. I finally figured out my problem. I also misspoke. In DashBoard if you want to work on a slightly complex data set (Layer A which intersects layer B for example) you have to create it via "Data expression".
We learn every day
Bye
Aurelian
