Adding related table to ArcGIS Online feature layer
88854
73
01-08-2019 10:26 AM
EricGardecki1
I'm trying to figure out how to add a relationship class (related table one-to-many) to a feature layer within AGOL. I do not have ArcGIS Desktop or Server (do have QGIS but I don't think that will help here).
The only info I was able to find led me to believe that it may be possible by editing the service definition JSON but I can't find any reference as to how to edit it to make it work.
What are my options here?
Also, is viewing/editing/adding to related tables supported in AGOL web apps yet (not just Collector)?
Thanks!!
KhaledHassen
Pl. provide me with some info and I can double check. What API you are calling, applyEdits, etc,?
I see the layer has the relationship set correctly.
DavidBuehler
Background - Feature layer is related to the table (table was created in Survey123 Connect in order to get the bind type of GUID) based on GlobalID and GUID.  Feature layer will be an existing set of features that now need maintenance records (hence the related records table).
Ideally,  it would be used in Field Maps and/or Collector.  Which currently do not push the related record back though it shows the table is there as a related record table.  Which then I would assume would also so in any web maps.  Web map has the see related records box checked.
Not sure what else I can share with you.  If you need something else please let me know because if this can be figured out this a game changer for lots of people.
Here is the JSON for the service:
"adminServiceInfo" : {
"name" : "rrtestv5",
"type" : "FeatureServer",
"cacheMaxAge" : 0,
"status" : "Started",
"database" : {
"datasource" : {
"name" : "db"
"currentVersion" : 10.81,
"serviceItemId" : "fabfe8d3af784fb7a16cc3942bd1bedf",
"serviceDescription" : "",
"hasVersionedData" : false,
"supportsDisconnectedEditing" : false,
"hasStaticData" : false,
"hasSharedDomains" : false,
"maxRecordCount" : 2000,
"supportedQueryFormats" : "JSON",
"supportsVCSProjection" : false,
"supportedExportFormats" : "csv,shapefile,sqlite,gpkg,filegdb,featureCollection,geojson,excel",
"capabilities" : "Create,Delete,Query,Update,Editing,Sync",
"description" : "",
"copyrightText" : "",
"spatialReference" : {
"wkid" : 102100,
"latestWkid" : 3857
"initialExtent" : {
"xmin" : -10064729.121092074,
"ymin" : 5558924.3042244306,
"xmax" : -10005952.429953229,
"ymax" : 5578801.8141854359,
"wkid" : 102100,
"latestWkid" : 3857
"fullExtent" : {
"wkid" : 102100,
"latestWkid" : 3857
"allowGeometryUpdates" : true,
"units" : "esriMeters",
"supportsAppend" : true,
"supportsSharedDomains" : true,
"supportsWebHooks" : true,
"supportsTemporalLayers" : true,
"layerOverridesEnabled" : true,
"size" : 16384,
"syncEnabled" : true,
"syncCapabilities" : {
"supportsAsync" : true,
"supportsRegisteringExistingData" : true,
"supportsSyncDirectionControl" : true,
"supportsPerLayerSync" : true,
"supportsPerReplicaSync" : true,
"supportsSyncModelNone" : true,
"supportsRollbackOnFailure" : true,
"supportsAttachmentsSyncDirection" : true,
"supportsBiDirectionalSyncForServer" : true
"supportsApplyEditsWithGlobalIds" : true,
"supportsReturnDeleteResults" : true,
"supportsLayerOverrides" : true,
"supportsTilesAndBasicQueriesMode" : true,
"supportsQueryContingentValues" : true,
"supportedContingentValuesFormats" : "JSON, PBF",
"supportsContingentValuesJson" : 2,
"editorTrackingInfo" : {
"enableEditorTracking" : true,
"enableOwnershipAccessControl" : false,
"allowOthersToQuery" : true,
"allowOthersToUpdate" : true,
"allowOthersToDelete" : false,
"allowAnonymousToQuery" : true,
"allowAnonymousToUpdate" : true,
"allowAnonymousToDelete" : true
"xssPreventionInfo" : {
"xssPreventionEnabled" : true,
"xssPreventionRule" : "InputOnly",
"xssInputRule" : "rejectInvalid"
"layers" : [
"adminLayerInfo" : {
"tableName" : "db_42239.user_42239.rrtestv5_POINT_LAYER",
"geometryField" : {"name" : "Shape"},
"xssTrustedFields" : ""
"id" : 0,
"enableUseOfScaleOutReplicasWhenEditable" : true,
"name" : "Point layer",
"type" : "Feature Layer",
"displayField" : "",
"description" : "",
"defaultVisibility" : true,
"editFieldsInfo" : {
"creationDateField" : "CreationDate",
"creatorField" : "Creator",
"editDateField" : "EditDate",
"editorField" : "Editor"
"editingInfo" : {
"lastEditDate" : 1629315116344
"relationships" : [
"id" : 1,
"name" : "myRel",
"relatedTableId" : 1,
"cardinality" : "esriRelCardinalityOneToMany",
"role" : "esriRelRoleOrigin",
"keyField" : "globalid",
"composite" : true
"isDataVersioned" : false,
"hasContingentValuesDefinition" : false,
"supportsCalculate" : true,
"supportsASyncCalculate" : true,
"supportsTruncate" : false,
"supportsAttachmentsByUploadId" : true,
"supportsAttachmentsResizing" : true,
"supportsRollbackOnFailureParameter" : true,
"supportsStatistics" : true,
"supportsExceedsLimitStatistics" : true,
"supportsAdvancedQueries" : true,
"supportsValidateSql" : true,
"supportsCoordinatesQuantization" : true,
"supportsLayerOverrides " : true,
"supportsFieldDescriptionProperty" : true,
"supportsQuantizationEditMode" : true,
"supportsReturningQueryGeometry" : true,
"advancedQueryCapabilities" : {
"supportsPagination" : true,
"supportsPaginationOnAggregatedQueries" : true,
"supportsQueryRelatedPagination" : true,
"supportsQueryWithDistance" : true,
"supportsReturningQueryExtent" : true,
"supportsOrderBy" : true,
"supportsDistinct" : true,
"supportsQueryWithResultType" : true,
"supportsSqlExpression" : true,
"supportsAdvancedQueryRelated" : true,
"supportsCountDistinct" : true,
"supportsPercentileStatistics" : true,
"supportsQueryAttachments" : true,
"supportsReturningGeometryCentroid" : false,
"supportsQueryWithDatumTransformation" : true,
"supportsHavingClause" : true,
"supportsOutFieldSQLExpression" : true,
"supportsMaxRecordCountFactor" : true,
"supportsTopFeaturesQuery" : true,
"supportsDisjointSpatialRel" : true,
"supportsQueryWithCacheHint" : true,
"supportsQueryAttachmentsWithReturnUrl" : true,
"supportsQueryAnalytic" : true
"useStandardizedQueries" : true,
"geometryType" : "esriGeometryPoint",
"minScale" : 0,
"maxScale" : 0,
"extent" : {
"wkid" : 102100,
"latestWkid" : 3857
"drawingInfo":{"renderer":{"type":"simple","symbol":{"type":"esriPMS","url":"RedSphere.png","imageData":"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","contentType":"image/png","width":15,"height":15}}},
"hasAttachments" : true,
"attachmentProperties" : [
"name" : "id",
"fieldName" : "ATTACHMENTID",
"isEnabled" : true
"name" : "globalId",
"fieldName" : "AttachmentGlobalID",
"isEnabled" : true
"name" : "name",
"fieldName" : "ATT_NAME",
"isEnabled" : true
"name" : "size",
"fieldName" : "DATA_SIZE",
"isEnabled" : true
"name" : "contentType",
"fieldName" : "CONTENT_TYPE",
"isEnabled" : true
"name" : "keywords",
"fieldName" : "Keywords",
"isEnabled" : true
"name" : "exifInfo",
"fieldName" : "ExifInfo",
"isEnabled" : true
"htmlPopupType" : "esriServerHTMLPopupTypeNone",
"hasM" : false,
"hasZ" : false,
"objectIdField" : "OBJECTID",
"globalIdField" : "GlobalID",
"typeIdField" : "",
"fields" : [
"name" : "OBJECTID",
"type" : "esriFieldTypeOID",
"alias" : "OBJECTID",
"sqlType" : "sqlTypeOther",
"nullable" : false,
"editable" : false,
"visible" : true,
"domain" : null,
"defaultValue" : null
"name" : "GlobalID",
"type" : "esriFieldTypeGlobalID",
"alias" : "",
"length" : 38,
"nullable" : false,
"editable" : false,
"visible" : true,
"domain" : null,
"name" : "CreationDate",
"type" : "esriFieldTypeDate",
"alias" : "CreationDate",
"length" : 8,
"nullable" : true,
"editable" : false,
"visible" : true,
"domain" : null,
"name" : "Creator",
"type" : "esriFieldTypeString",
"alias" : "Creator",
"length" : 128,
"nullable" : true,
"editable" : false,
"visible" : true,
"domain" : null,
"name" : "EditDate",
"alias" : "EditDate",
"length" : 8,
"nullable" : true,
"editable" : false,
"visible" : true,
"domain" : null,
"name" : "Editor",
"alias" : "Editor",
"length" : 128,
"nullable" : true,
"editable" : false,
"visible" : true,
"domain" : null,
"name" : "facid",
"alias" : "FacilityID",
"length" : 256,
"nullable" : true,
"editable" : true,
"visible" : true,
"domain" : null,
"name" : "Comments",
"alias" : "Comments",
"length" : 256,
"nullable" : true,
"editable" : true,
"visible" : true,
"domain" : null,
"indexes" : [
"name" : "GlobalID_Index",
"fields" : "GlobalID",
"isAscending" : false,
"isUnique" : true,
"description" : ""
"name" : "user_42239.rrtestv5_POINT_LAYER_Shape_sidx",
"fields" : "Shape",
"isUnique" : false,
"description" : "Shape Index"
"name" : "PK__rrtestv5__F4B70D855C3DCA2D",
"fields" : "OBJECTID",
"isAscending" : true,
"isUnique" : true,
"description" : "clustered, unique, primary key"
"name" : "CreationDateIndex",
"fields" : "CreationDate",
"isUnique" : false,
"description" : "CreationDate Field index"
"name" : "CreatorIndex",
"fields" : "Creator",
"isUnique" : false,
"description" : "Creator Field index"
"name" : "EditDateIndex",
"fields" : "EditDate",
"isUnique" : false,
"description" : "EditDate Field index"
"name" : "EditorIndex",
"fields" : "Editor",
"isUnique" : false,
"description" : "Editor Field index"
"dateFieldsTimeReference" : {
"timeZone" : "UTC",
"respectsDaylightSaving" : false
"preferredTimeReference" : null,
"types" : [],
"templates" : [
"name" : "New Feature",
"description" : "",
"drawingTool" : "esriFeatureEditToolPoint",
"prototype" : {
"attributes" : {
"facid" : null,
"Comments" : null
"supportedQueryFormats" : "JSON, geoJSON, PBF",
"supportedAppendFormats" : "sqlite,gpkg,shapefile,filegdb,featureCollection,geojson,csv,excel,imageCollection",
"standardMaxRecordCount" : 32000,
"standardMaxRecordCountNoGeometry" : 32000,
"tileMaxRecordCount" : 8000,
"maxRecordCountFactor" : 1,
"exceedsLimitFactor" : 1
"tableName" : "db_42239.user_42239.rrtestv5_RRTESTV5T2", "geometryField" : null,
"id" : 1,
"name" : "rrtestv5t2",
"type" : "Table",
"description" : "",
"editingInfo" : {
"lastEditDate" : 1629314788379
"relationships" : [
"id" : 1,
"name" : "myRel",
"relatedTableId" : 0,
"role" : "esriRelRoleDestination",
"keyField" : "GUIDID",
"composite" : true
"hasAttachments" : false,
"hasM" : false,
"hasZ" : false,
"globalIdField" : "globalid",
"typeIdField" : "",
"fields" : [
"name" : "objectid",
"alias" : "ObjectID",
"nullable" : false,
"editable" : false,
"visible" : true,
"domain" : null,
"name" : "globalid",
"alias" : "GlobalID",
"sqlType" : "sqlTypeGUID",
"length" : 38,
"nullable" : false,
"editable" : false,
"visible" : true,
"domain" : null,
"name" : "FACILITYID",
"alias" : "Facility ID",
"length" : 50,
"nullable" : true,
"editable" : true,
"visible" : true,
"domain" : null,
"name" : "DATE",
"alias" : "Date",
"length" : 255,
"nullable" : true,
"editable" : true,
"visible" : true,
"domain" : null,
"name" : "INSPECTOR",
"alias" : "Inspector",
"length" : 50,
"nullable" : true,
"editable" : true,
"visible" : true,
"domain" : null,
"name" : "CONDITION",
"alias" : "Condition",
"length" : 50,
"nullable" : true,
"editable" : true,
"visible" : true,
"domain" :
"type" : "codedValue",
"name" : "cvd_CONDITION",
"codedValues" : [
"name" : "Excellent",
"code" : "Excellent"
"name" : "Very Good",
"code" : "Very Good"
"name" : "Good",
"code" : "Good"
"name" : "Fair",
"code" : "Fair"
"name" : "Poor",
"code" : "Poor"
"name" : "Very Poor",
"code" : "Very Poor"
"name" : "Unknown",
"code" : "Unknown"
"name" : "COMMENTS",
"length" : 1000,
"nullable" : true,
"editable" : true,
"visible" : true,
"domain" : null,
"name" : "GUIDID",
"type" : "esriFieldTypeGUID",
"alias" : "GUID",
"length" : 38,
"nullable" : true,
"editable" : true,
"visible" : true,
"domain" : null,
"length" : 8,
"nullable" : true,
"editable" : false,
"visible" : true,
"domain" : null,
"name" : "Creator",
"length" : 128,
"nullable" : true,
"editable" : false,
"visible" : true,
"domain" : null,
"length" : 8,
"nullable" : true,
"editable" : false,
"visible" : true,
"domain" : null,
"name" : "Editor",
"alias" : "Editor",
"length" : 128,
"nullable" : true,
"editable" : false,
"visible" : true,
"domain" : null,
"indexes" : [
"name" : "UK_rrtestv5_RRTESTV5T2_globalid",
"fields" : "globalid",
"isUnique" : true,
"description" : "nonclustered, unique"
"name" : "PK__rrtestv5__5242E6323C0B1297",
"fields" : "objectid",
"isUnique" : true,
"timeZone" : "UTC",
"types" : [],
"templates" : [],
"supportedAppendFormats" : "sqlite,gpkg,shapefile,filegdb,featureCollection,geojson,csv,excel",
EmHain
QGIS now supports this a bit better, this blog details it.
