Hi
I'm trying to create a map of landowners and want to add labels so their names are visible on the map without having to click on a property.
I have created a sketch layer and used that to draw polygons outlining of each landholding. For any publicly available layers that I have added to my map there is a label option in the right toolbar. If I click on my sketch layer there is no label option.
Am I missing something, or are labels not available for sketch layers?
hi @HM1, there are no fields in sketches so the label button will not appear. That being said you can manually label sketches using the text option. Hope this helps!
