Adding data from GIS server to ArcGIS Online
1436
02-28-2012 06:10 AM
IT_DeptDept
Hello:
I am trying to create an interactive map  apps for Town using ArcGIS Online templates. I uploaded data directly from GIS server and works fine. But I could not figured out to change the symbology to uploaded data. It seems that only I can mange is pop-up in online map viewer. Is there any option I can manipulate some features like symbology, transparency etc.
Thank you !
MikeMinami
Esri Notable Contributor
When you add layers to the map based on map services, the symbolization is defined by the service itself. You can adjust the transparency of the service as a whole, however, by clicking the arrow next to the layer name in the Contents panel.
You can also add individual layers from your map service as an individual layer in the web map. Choose the Add>Layer from web and enter the URL to a particular layer, like this:http://gisweb.brooklinema.gov/ArcGIS/rest/services/whereami/MapServer/3. In this case, the layer gets loaded into the web map and drawn by the web browser. This works for small numbers of features and is also browser specific. If you add too many features, the performance will suffer.
Mike
IT_DeptDept
Thanks Mike !
I may have some questions about web map customization later on my progress.
RussellShirley
Mike,
I have created a map with a sipmple polygon to show an outline of my companys service area and areas that are out of power. I just added the layer and connected to our ArcGIS server. It works but the performance of our layer is terrible. When I view the service using the javascript viewer the performance is acceptable, about what it is in ArcMap. The service must be dynamic becasue the data that drives the layer changes regularly. I went that route to prevent form having to serve up the basemap.
This is the like to my map. http://www.arcgis.com/home/webmap/viewer.html?webmap=aa8bab9079c24063a8e89b213ce03467
What tips can you give me to improve preformance?
Is their a different or perfered way of achiveing the same map?
Thanks, Russell
MarcWeinshenker1
Mike,
Thanks, Russell
One possibility of the performance hit is that the spatial reference of your data is WKID 2239 so that it has be re-projected on the fly to match the base map which is in Web Mercator Aux Sphere  102100 (3857).   One way around that is to re-project the data yourself and create a service from that, but doing so may not be practical if your data changes often.
Marc
