Adding arcgis.com layers not working in ArcGIS Desktop application
1729
5
06-09-2011 06:26 AM
JeffreyHill
I am having an issue trying to "Add Data From ArcGIS Online...".  I'm using version 9.3.1.  When I click to add the online data, I get a broken layer...
MikeMinami
Esri Notable Contributor
Is the data you're trying to add a public item?  Can you share a link to it?
What type of item is it?
Mike
JeffreyHill
Mike
Here is the file I'm trying to open, but it's pretty much every .lyr that i've tried to open:
MikeMinami
Layer files don't contain any data, so they often can't be drawn in arcmap, unless you have access to the source data the lyr references. So if you work at the same organization as someone sharing the lyr file and the source of the lyr is a geodatabase that you can see, the layer will draw. However, if you don't have access to the source, it will appear as a broken layer.
If the source data of the lyr file is a map service, then it should display fine. Since you are trying to display world imagery, am I correct in assuming that you want to find basemap layers? Here's a link to the basemap layers that Esri provides.
http://links.esri.com/arcgisdesktop/en/arcmap931/layers
Hope this helps,
Mike
JeffreyHill
That is exactly what is not working... the layers from the ESRI map service.  The imagery layer from the link provided is the sample I sent in my post above.  It worked fine last week, and now shows the layers as broken???
MikeMinami
http://www.arcgis.com/home/item.html?id=a5fef63517cd4a099b437e55713d3d54
This layer is working for me... I'm not sure why you can't see it. Is there a network issue at your site? If not, I'd suggest calling Esri Technical Support.
Mike
