Adding a CSV file to arcgis online
1842
11-15-2011 02:26 PM
SubhadipGhosh
I have looked at the previous threads and I have tried doing as asked but I have not been able to add a simple txt file with csv values to my online maps. It shows the error -
"File does not contain fields with point coordinates".
This is exactly what I have in the file (attached as well)-
16.02,23.45
-12.33,9.34
Can someone who has done this please tell me how to fix this.
I would appreciate if you don't link me to some help file - I have already looked into
http://help.arcgis.com/en/arcgisexplorer/help/index.html#//01560000004t000000 and
http://help.arcgis.com/en/arcgisonline/help/index.html#//010q00000060000000
doesn't really help.
Also is this method guaranteed to work when there are multiple fields of which 2 of them are coordinates - rest are some other metadata?
Subhadip
MikeMinami
Esri Notable Contributor
You need to add a header line to the file that defines the fields
lat,long
16.02,23.45
-12.33,9.34
Mike
SubhadipGhosh
thanks Mike. That worked.
I wonder why the help documents are so ambiguous.
MikeMinami
Typically, the first record of the CSV contains the names of the fields. I guess the author of help assumed people know that. We can try to make that more clear in the documentation.
Mike
