Add Feature Polygon via REST API
3536
08-11-2021 01:28 PM
Labels (3)
lougalban
I'm trying to add a feature layer via REST API, but its not working. I only have 4 corners coordinates. Below is my code.
'geometry' => [
                'hasZ'  => false,
                'hasM'  => false,
                'rings' => [[[121.458756,15.807697],[121.458784,15.807773],[121.459115,15.807692],[121.459088,15.807596],[121.458756,15.807697]]],
                'spatialReference' => [
                    "wkid" => 4326
Any idea?
DavidPike
MVP Notable Contributor
which api is this? I don't get the syntax =>
Shouldn't rings be closed off with a repeat of the initial vertex?  Do you have a reference to where you've got this from?
lougalban
Hi thank you for the response, I'm very new to ArcGIS. It was close, first and last is same coordinates.. Did I do it wrong?
This is my reference:
Add Feature API:
https://developers.arcgis.com/rest/services-reference/enterprise/add-features.htm
Geometry Polygon:
https://developers.arcgis.com/documentation/common-data-types/geometry-objects.htm
AmandaRing
You need to create a properly formatted JSON feature object.
It would look something like:
	"geometry": {
		"rings": [
				[121.458756, 15.807697],
				[121.458784, 15.807773],
				[121.459115, 15.807692],
				[121.459088, 15.807596],
		"spatialReference": {
			"wkid": 4326
Amanda
Product Engineer - Web Analysis
