Access and edit Field Groups and Contingent Values in ArcGIS Online
688
09-06-2022 11:50 PM
AdminWPZ
Hi all,
I have a Hosted Feature Layer (published from a ArcGIS Pro File GDB to ArcGIS Online). Before publishing the layer I defined Field Groups and Contingent Values. I also wrongly set the Field Groups to Restrictive and would like to correct this now.
Is there a way to access / edit Field Groups directly in AGOL? Adding the hosted layer into ArcGIS Pro does not work (the Field Group settings are readonly, i.e. they're not listed at all).
If it isn't possible to edit the Field Groups in AGOL,
  • I assume the best way would  be to export the layer to a FGDB, change the settings in ArcGIS Pro and then overwrite the existing layer?
  • Is there a plan to make Field Groups and Contingent values accessible in AGOL?
Thanks for all hints and ideas,
Andrea
