A simple arcade question
7084
8
09-04-2018 06:06 PM
CandiceBardsley1
Hi - I am new to arcade so need to ask a very simple question...
Is there an 'and' function?
I want to show a warning symbol if a threshold (1951) is met. Each of the objects in the feature class has a different threshold hence I want to isolate each object, then set a value for it.
I've tried the expression below but 'and' mustn't be an option.
If ($feature.OBJECTID=9) and ($feature["PI_Value"] >1951)
{return "warning"} else {return "ok"}
Any help would be greatly appreciated...
Tags (1)
XanderBakker
Esri Esteemed Contributor
Depending on the number of features and different thresholds you have you could have a dictionary that stores the thresholds per ObjectID and you check the PI value against that threshold:
var thresholds = {"9": 1951, "10": 1749, "11": 2103};
var oid = Text($feature.OBJECTID);
var pi_value = $feature["PI_Value"];
if (pi_value > thresholds[oid]) {
    return "warning";
} else {
    return "ok";
However, it is better to have a threshold stored at feature level (in a field) and compare against it:
var threshold = $feature["Threshold"];
if (pi_value > threshold) {
    return "warning";
} else {
    return "ok";
Concerning the error you obtained, you need to use the double equal to compare value (single equal sign is an assignment):
If (($feature.OBJECTID==9) && ($feature["PI_Value"] >1951)) {
    return "warning";
} else {
    return "ok";
johnmosheim1
Is this what you are looking for?
JM
CandiceBardsley1
Hi John
I’ve tried this:
If ($feature.OBJECTID=9) && ($feature["PI_Value"] >1951)
But get a parse error: unexpected token &&
So I must still be doing something wrong.
XanderBakker
    return "warning";
} else {
    return "ok";
    return "warning";
} else {
    return "ok";
    return "warning";
} else {
    return "ok";
CandiceBardsley1
Thanks Xander, the double == solved my problem. Regarding the second option of having the threshold stored at feature level, I didn't do this because in the case of this feature class, some of the thresholds are actually when the pi_value is lower than the threshold number, so your script wouldn't work in this instance.
Your first option of using a dictionary has taken what I originally asked for to the next level and is perfect for what I am after. For some reason though when I enter the script like you've written it I get Execution Error:Field not Found...
Is there something missing or do I need to have a threshold entered for every object ID for this to work?
XanderBakker
Let's answer this in parts:
 I think the whole idea of testing a value against a threshold is to determine if the value is low or higher and should yield in either "ok" or "warning". So this should work (in theory).
This error is likely to occur when you are trying to retrieve the threshold value for a certain ObjectID which is not included in the dictionary. Not sure if this should yield the "Execution Error:Field not Found" error.
To avoid this you could use the following code:
function TestThreshold(thresholds, oid, pi_value) {
    var result  = "oid not found"
    for (var key in thresholds) {
        if (key == oid) {
            var threshold = thresholds[key];
                 result = "warning";
            } else {
                 result = "ok";
    return result;
return TestThreshold(thresholds, oid, pi_value);
CandiceBardsley1
Awesome, that is working like a dream. Thanks for the help!
XanderBakker
You're welcome. Glad it works!
johnmosheim1
Hi Candice, I'm not a wiz but maybe this might do it ("if" expression does not appear to have the right syntax)
John
