9.0 Installer error 1904
2557
02-02-2016 11:28 AM
JohnGreen
New Contributor II
- When I try to install ArcGIS 9.0 on my tablet with XP pro I get the following message in an Installer Information box: Error 1904 Module D:\Program Files\ArcGIS\Bin\XMLSupportUI.dll failed to register. HRESULT-2147023898. Contact your support personel.  Can anyone tell me what might be wrong?
RebeccaStrauch__GISP
Take a look at
28065 - Error 1904: failed to register C:\Program Files\ArcGIS\Bin\xmlsupportui.dll, 3dsymbolsui.dll...
and Other trouble installing ArcGIS 9 - Error 1904, HRESULT -2147023898
for other possible solutions, do  web search for " arcgis 9.0 install error 1904 "
edit...having issues with my connection right  now....but here is a knowledge base doc that might also be helpful
http://support.esri.com/en/knowledgebase/techarticles/detail/27259/pdf
Take a look at
JohnGreen
New Contributor II
Thanks Rebecca.  That worked for us.
Glad it worked. remember to mark it as the correct answer so this thread can be closed.
