When Searching for members, find searched string anywhere in username, not just at beginning
188
09-03-2025 02:05 PM
Status: Open
PatIampietro
Currently, when searching for members in the Member GUI for the organization, the characters entered in the "Search" box will only return correct results for those members that have the searched string at the beginning of their First Name, Last Name, or username. This limitation is not documented anywhere and not only reduces the power of the search tool, it can lead to incorrect expectations and confusion regarding its results.
For example, the username Johnsmith_agol would only come up if searching using "J" "Jo" "Joh" etc... Searches like "_agol" or even "ohnsmith_agol" will not return the result. This issue is documented in Tech Supprt Case https://my.esri.com/#/support/cases/tech-cases?caseNumber=03988615. Development has reviewed an enhancement request (https://my.esri.com/#/support/bugs/bugs?bugNumber=ENH-000107730) for usernames containing the searched characters anywhere to return as results, and have closed that request out and will not be addressing it.
This Idea is to solicit support for a search tool that finds the searched characters if they occur anywhere in the target fields. Use cases are many, but one example involves trying to find all members that were incorrectly assigned usernames with an organization shortname in all lowercase appended to their SAMLID, contrary to our New User Defaults (this was due to a BUG https://my.esri.com/#/support/bugs/bugs?bugNumber=BUG-000179029). Because the characters occur at the end of the username, they are unsearchable. Another means of finding the affected members must be employed.
A search tool should find what it is looking for. Or at the very least the cases where it won't should be documented.
Note: this is related to this quite old Idea- https://community.esri.com/t5/arcgis-online-ideas/agol-admin-make-user-filters-work/idi-p/937925
1 Comment
VenkataKondepati
100% agree with this. A search tool should behave like a true contains search, not just “starts with.” The current behavior is unintuitive, undocumented, and leads to missed results — especially in large orgs where usernames and SAML IDs follow different patterns.
In our case, we’ve also had to hunt for members where the key identifier is embedded at the end of the username, which is currently impossible through the Member search. Workarounds (manual exports, scripts, or API calls) add unnecessary overhead for something that should be native in the admin UI.
At minimum, Esri should:
  • Add “contains” and “exact match” search modes in the Members UI.
  • Or clearly document that search only matches from the beginning of strings.
This would bring Member search in line with user expectations and save administrators time. +1 from me.
— Venkat
