WAB Infographics widget (Pie/Dount Chart) does not pull layer symbology from a results layer
690
05-31-2019 10:08 AM
Status: Open
MichaelSchoelen
When using the WAB Infographics widget in the Infographics template, the option to select a layer's symbology from a Query Result layer is hidden.
With a regular feature layer:
1) A layer is selected from Map
2) Under Display settings, "Use layer's symbology" is available as an option
With a Query result output layer:
1) A layer is selected from Extra data source
2) Under Chart settings > Display, the option for "Use layer's symbology" is not available as an option
The Query result layer is using "symbols defined by the layer" in this scenario.
Use symbols defined by the layer
Is there another way around this restriction?
