Update only edited fields when syncing hosted feature service
4040
6
05-10-2019 01:42 PM
Status: Open
WalkerHenry__NIFCAdmin
Would it be possible for edits coming in via Sync to be updated by attribute instead of by row for ArcGIS Online hosted feature services?
We have issues with field users taking Collector offline in the morning (and updating certain fields) overwriting bulk updates (on different fields) done in the office when they sync at night.  Examples of the issue are provided in the GISS Workflow here as watch-out situations.
Having a mechanism to allow for multiple offline editors to touch the same feature without guaranteed data loss would be a major improvement for us.
6 Comments
RussellBrennan
If you set up your services such that they are published from a versioned dataset (enterprise geodatabase) and you publish by reference instead of a hosted service, this is already supported.
See: https://enterprise.arcgis.com/en/server/latest/publish-services/windows/offline-maps-and-versioned-d...
This is also a video from 2.1 (but still relevant) for working with versioned data: https://youtu.be/6VnRHvWWjjA?t=796
With this workflow you can perform reconciles after edits have been synced and choose how you want to define conflicts.
I am not sure if this would be helpful for your needs. Or perhaps your request is more specific to working with Hosted data?
KoryKramer
Hi @WalkerHenry__NIFCAdmin I'm doing some housekeeping here in the ArcGIS Pro idea exchange and saw this marked as Needs Clarification.  Russell provided some information above and asked if you are looking for this to work with hosted data (e.g. hosted feature services in ArcGIS Online).
Let us know if that is the case and if so, we can clarify that in the idea's title and description and get it re-opened.
Thanks!
Hi @KoryKramer,
Thanks for the @.
This would be specific to AGOL Hosted Feature Services.
Training and communication has lessened the impact of this, but a mechanism to allow for multiple offline editors to touch the same feature without guaranteed data loss would still be a major improvement for us.
Thanks!
KoryKramer
Thanks for the clarification @WalkerHenry__NIFCAdmin
There was a bit of deliberation internally about this and the problem arises because while the main idea appears to be about sync, you then mentioned versioned data.  We really want to get this idea opened back up, but to do, we're proposing that we update the title to:
Update only edited fields when syncing hosted feature service.
And the idea's description to:
If you're OK with that, let me know and we'll update and re-open the idea.
Thanks
@KoryKramer ,
Sounds good to me, thanks!
KoryKramer
Status changed to: Open
Updated and opened.  Thanks @WalkerHenry__NIFCAdmin
