Symbol Property Connections (Attribute-Driven Symbology)
6336
17
01-24-2023 12:33 PM
Status: Open
wayfaringrob
Honored Contributor
I would greatly appreciate the ability to use field values as symbology values, as is possible in ArcGIS Pro when checking the box for 'Allow symbol property connections.' In fact, I have a layer that uses this for color. It uses single symbol symbology, but each feature appears a different color since the hex code is stored in a table and set up to do so. When I go to publish online, though, not only does it not give any warning that this is not supported in AGO, but my features upload with a default gray appearance. The only workaround seems to be to manually set the color of each symbol class and to save that to the layer, which is still undesirable as it results in massive legends that aren't really necessary and manual labels for everything. Transparency by attribute is already an option, but there ought to be parity with Pro in this regard.
17 Comments
RussRoberts
When you go to that layer in Pro click on the expression icon next to Map Color and switch the dropdown from VBScript to Arcade. Then publish the map up and it should look like the one I posted back into the group.
MatthewKing
@RussRoberts Wow, big big thanks, that worked!  Is that basically what you did when you used AGO-Assistant?
Another question, in Pro or AGO, or using AGO-Assistant, is there a way for the legend to reflect the color?  Instead it seems that they're just some random color.
ArcGIS OnlineArcGIS OnlineArcGIS ProArcGIS Pro
RussRoberts
Yup a while back as things were still being worked on across teams I had to use assistant to get the properties to be in arcade and there was 1 or 2 other areas where we on the web side weren't fully supporting. Now with the above case just using Pro (I used the latest version here) and making sure when you set the field to go through the expression builder just to explicitly set it as arcade instead of vbscript.
When using these field connected primitive overrides both clients are currently limited with the legend support and we cant extract that color. I don't have a release when this is supported unfortunately.
MatthewKing
@RussRoberts bummer about your 2nd paragraph b/c that kind of stops me in my tracks.  I really need the legend to reflect the trail colors.  I'll submit a separate AGO Idea for that.
Thanks again for your help.  While in the end I'll need to find an alternative (or do the symbology of all 130+ trails manually) this was helpful and I did learn something new.
wayfaringrob
@MatthewKing  it's an unfortunate limitation in ArcGIS Pro, too. You can get attribute-driven symbology, sure, but even that doesn't have full support. In addition to having an inadequate legend, you can't set symbol layer drawing either. It would be best if attribute-driven symbology would just act like normal symbology. That would be insanely useful.
MatthewKing
@wayfaringrob  I hear you...I'm really grateful that they have this really cool feature, but like you allude to, it's not all the way there yet.
Also, thanks for letting me highjack your post 😁
A_Stan
by Esri Contributor
In case it helps anyone:
I encountered this issue and wrote a little python script which uses the colour columns to manually change the layer colours, allowing you to export to AGOL.
import arcpy
# Set the path to your feature layer
layer_path = r"C:\......"
# Create a layer object
aprx = arcpy.mp.ArcGISProject("CURRENT")
map = aprx.listMaps('YourMapName')[0]
layer = map.listLayers("YourLayerName")[0]
#Convert hexcodes to RGB
def hex_to_rgb(hex_code):
    hex_code = hex_code.lstrip('#')
    rgb = [int(hex_code[i:i+2], 16) for i in (0, 2, 4)]
    rgb.append(100)
    return {'RGB': rgb}
# Start an edit session
with arcpy.da.Editor(layer_path) as edit:
    # Create an update cursor to iterate through the features
    with arcpy.da.UpdateCursor(layer, ["UniqueIdentifier", "Colour1", "Colour2"]) as cursor:
        for row in cursor:
            # Get the values of Colour1 and Colour2 fields
            colour1 = hex_to_rgb(row[1])
            colour2 = hex_to_rgb(row[2])
            # Modify symbology for the layer
            sym = layer.symbology
            if hasattr(sym, "renderer") and sym.renderer.type == "UniqueValueRenderer":
                # Update the renderer's symbol properties
                for group in sym.renderer.groups:
                    for item in group.items:
                        if item.label == row[0]:  # Match the "Team" field
                            item.symbol.color = colour1
                            item.symbol.outlineColor = colour2
                # Apply the updated symbology to the layer
                layer.symbology = sym
            # Update the row
            cursor.updateRow(row)
print("Colours updated successfully.")
 This was used for assigning colours to football teams. The team name takes the place of UniqueIdentifier field, and the Colour1 and Colour2 fields containing hexcodes are used to give fill and outline values.
