Show Survey123 forms as "Forms" instead of "Apps" in ArcGIS Online
180
4 weeks ago
Status: Open
LindsayRaabe_FPCWA
MVP Regular Contributor
In ArcGIS Online, items that are forms created in Survey123 are categorised as "Apps" when searching Content or setting up Content Blocks on the AGOL Home Page. This means that when filtering Content, you can select "Apps" on the left and you get everything from ExB Apps, Dashboards, etc and Forms. There are subcategories, but unless I'm missing something, Forms is not an option.
Also, on the Home Page Content Blocks, Forms can't be filtered in or out as required. Currently they show up with other Apps despite wishing they weren't. The only way around this at present would be to separate them into a separate group (more admin).
IDEA: Add in a "Forms" category so that Survey123 forms can be filtered independantly of other items when searching Content or arranging Content Blocks on the Home Page.
2 Comments
rflorence
AlfredBaldenweck
Not surprising. I had a similar thing with code samples: Content filtering: Add a "Code Sample" option unde... - Esri Community
