Radius dimensions for drawing circles
2313
10-12-2011 08:03 AM
Status: Open
SueCarroll
Just as you can see the length as you draw a line, it would be helpful to see the radius of the circle you are drawing.  We have users that need to draw circles around points to see if other features are within set distances.  The clunky workaround is to draw a line with the proper radius length, then draw a circle using both ends of the line to define the center and radius.  Then the line must be deleted.  There should be an easier way!
4 Comments
JurajKrumpolec
To see radiusmodify radius while drawing and change radius after the circle is drawn should be definitely made available. The same goes for all regular-shaped features/graphics as requested in Universal Control Panel.
AmySteiger
This is available in v10, when you use the Circle construction tools, you can left click to start drawing a circle then right click and enter a radius measurement. Alternatively, as you draw the circle, down the bottom left it gives you dimensions such as area, circumference and radius.
Cheers,
Amy
AmySteiger
Oops, I did not read that this was for ArcGIS Online until I pressed Post Comment
MatthewStull1
It looks like this functionality still isn't in ArcGIS Online.  I was trying to find it in the Experience Builder today and all I see the same measuring tool widget that has been in ArcGIS Online for a long time.  This is an old thread but the need for this tool remains.  I was asked for it by the Emergency Management Manager at the agency I work for recently.
