New map viewer - allow filtering using two date fields in the same feature layer
839
11-23-2022 08:30 AM
Status: Open
tmichael_wpjwa
Map viewer classic includes the ability to create filters based on two date fields:
It would be great if the same ability were enabled in the new map viewer.
Tags (3)
1 Comment
GeneOlig
Thank you for posting this idea.  I submitted an ESRI case, in which an enhancement request was generated.  Here is the correspondence:
I completely understand and agree that this should be a core functionality especially since it is available in ArcGIS Pro and Map Viewer Classic. I'll be sure to note that with our internal team as well. I'm glad we were able to get the enhancement logged and definitely encourage giving a "Kudos" to the following Esri Community Ideas post to help bring additional attention to the request by our internal teams.
To summarize our case:
-You've noted that the Filter by Field option is available in ArcGIS Pro and Map Viewer Classic, but is not available in the new Map Viewer.
-I was able to confirm this as well, and found a post in the Esri Community Ideas where this feature is also being requested.
-We created the following enhancement for our case:
  • ENH-000165072: Request to add the option to filter by field in Map Viewer.
