Map layers not drawing properly at certain scales in AGOL
1136
09-06-2024 01:54 PM
Status: Open
NolanHoffart
Hello everyone,
I am having troubles with layers drawing properly in AGOL. The layer only draws properly at certain scales. When it is not drawing properly, the layer is patchy and missing sections. I have tried generalizing the data thinking that the data was too large, but that hasn't helped. I have also turned on Optimize layer drawing for all of the layers and it does help but doesn't fully solve the issue. I have had this issue with other layers before and I cannot figure out the best solution to this issue.
I have attached a .ppkx containing one of the layers that is not working properly to the bottom of this post.
Any help is appreciated!
Thanks!
Not Drawing Properly.pngThis is what it looks like when the layer does not draw properlyDrawing.pngThis also doesnt draw 100% correctly, but draws better than the other.
2 Comments
RussRoberts
Can you share a pro project or sd file and we can publish and check it out. Have you also tried rebuilding spatial indexes? thanks!
NolanHoffart
Hey thanks for the reply @RussRoberts. I have tried rebuilding spatial indexes and that also did not help any.
I have uploaded a .ppkg in the post; I really appreciate any help and insight into this.
Nolan
