Enable/disable editing on tables in Map Viewer
1041
03-14-2024 12:17 PM
Status: Open
BrendanMadden
In Map Viewer, the ability to enable/disable editing is available in the Properties for feature layers that are editable.
It would be great to have the same option for tables as well - this is possible in Map Viewer Classic.
In my particular use-case, I have two tables in a map with a related feature layer, and need one to be editable and one to be read-only. I can do this through Map Viewer Classic for now, but it seems like it should be doable in Map Viewer too.
1 Comment
BrennanSmith1
One workaround for this is to use the ArcGIS Assistant to edit the JSON of a webmap directly. Find the Tables section, and for the specific table you are interested in, add an entry for:
"capabilities": "Query,Sync",
 which will disable editing.  I agree that there should be an easier, intuitive way to do this directly from the webmap though!
