change editing templates for feature services on ArcGIS Online
1402
03-27-2023 11:10 PM
Status: Open
MarcelLameijer
changing the editing template for a feature layer in ArcGIS Online is not possible in het current viewer. The workaround is nog switching to the Classic Viewer or using ArcGIS Pro.
Some things unexpectedly break (broke a least) while using the Classic Viewer to change the editing template and then use the current viewer / tools again.
Making the changing of the editing template available in the new viewer, prefererably in the same place as changing the feature visualisation would be the best an logical place.
1 Comment
RussRoberts
Currently we do not exposing editing the templates in Map Viewer but Field Maps Designer supports managing templates and supports the same web map properties as Map Viewer.
https://doc.arcgis.com/en/field-maps/android/help/configure-the-map.htm#ESRI_SECTION1_93E449067ECE49...
