Change attribute field order in Map Viewer Editor window
3169
06-10-2024 12:33 PM
Status: Open
tschulzke
In Map Viewer Classic, the attribute field order for a layer's pop-up is maintained in the editing window as well, which seems to be a natural and logical behavior, because if you wanted the fields to be viewed in a particular order, it stands to reason that you would want to edit them in the same order (it provides consistency and predictability when the attributes are ordered the same in both views).
In the new Map Viewer, however, the attribute field order in the Editor window follows the order of the layer's original attribute table, not the order configured in the attributes pop-up. There appears to be no option for re-ordering the attribute fields for the Editor window, including moving columns in the layer's attribute table.
As mentioned above, the logical behavior for ordering attribute fields is that they are the same in the pop-up as they are in the editing window. In other words, I can't think of a scenario where you would want those two views to be different, but even if you did, there is no way to configure the Editor window field order. That said, either option/scenario (Editor window mimics the field order configured in the attributes pop-up OR Editor window field order can be custom configured such that it differs from the layer's original attribute table and from the attributes pop-up) would be better than the current limitation.
Tags (3)
5 Comments
EmilyGeo
Hi @tschulzke
The way to control the order in which fields are displayed in the Editor window is to create a Form. If you have not created a form, the Editor window displays a list of all the editable fields by default.
To get started with forms, select the editable layer, click Configure Editing on the toolbar on the right and select Forms. If you want the field order to mirror the pop-up, you can do that with just 1 click.
Other options include dragging, dropping and reording fields to tailor the form for editing. For more information on configuring forms in Map Viewer, check out this article.
ACrateau
Hi @EmilyGeo ,
Thank you for this response, the Forms functionality is great, but is tied to each web map.  I think @tschulzke 's idea is still valid if you have an enterprise layer in many web maps, and need to update the field order globally.
EmilyGeo
Hi @ACrateau ,
Forms can be saved to the map or to the layer.
Save the Form to the Layer:
  • By saving the form to the layer, the form appears with the fields in the same order every time you add the layer to a map. This ensures consistency and saves you from recreating the form for each web map.
AdamGaudet
Reply to above - I don't see this as an option in Visualization - is there something I'm missing?
EmilyGeo
Hi @AdamGaudet
You can manage forms in Map Viewer or in Field Maps Designer. Access through the Visualization tab is not supported yet, but is on our future roadmap.
