Better Help for the Conditional Elements of Survey123's Report Template
3208
07-20-2018 05:49 AM
Status: Open
LiamHarrington-Missin
Currently the only help I can find on this is a small section in this link.  This is a potentially powerful feature in creating custom formatted reports and some extra help in a blog (with examples) would help users make better use of it.
5 Comments
ZhifangWang
Hi all,
Thanks for your feedbacks.
We have the conditional elements section documented in the help topic now: Feature report templates—Survey123 for ArcGIS | ArcGIS . Did you find it useful?
MatFeltner
I'm getting 'generate' errors when use conditional syntax in my Word document like:
Owner:                                                  ${SiteTreeOwnership}
Type of Failure:                                    ${TreeFailureType}
${if ${TreeFailureType} == “TF”}
Trunk Failure Height:          ${TrunkFailureHeight}
Trunk Failure Diameter:     ${TrunkFailureDiameter}
Errors:
Error occurred when checking the report template. The tag beginning with "${TreeFail" is unclosedThe tag beginning with "${# " is unclosedThe tag beginning with "} == “RF”" is unopenedThe tag beginning with "${TreeFail" is unclosedThe tag beginning with "${# " is unclosedThe tag beginning with "} == “TF”" is unopenedThe tag beginning with "${TreeFail" is unclosedThe tag beginning with "${# " is unclosedThe tag beginning with "} == “BF”" is unopenedThe loop with tag "" is unopenedThe loop with tag "" is unopenedThe loop with tag "" is unopened
Failed Object IDs
DudleyHartel
Using this documented syntax in Word document...
${if ${TreeFailureType} == “RF”}
Root Failure Type:               ${RootFailureType}
${if ${TreeFailureType} == “BF”}
Branch Diameter:                ${BranchBreakDiameter}
Branch Length:                     ${BranchLength}
I get error messages...
DudleyHartel
I determined the syntax error with some trial and error...
  1. within the $If{ } ... $if{/} sequence, the attributes used in the expression use their Survey123 Excel workbook name WITHOUT the ${<name>} syntax
  2. the equality '==' within an If expression is also the Excel workbook "choices" label NOT the name.
This works...
Failure:
${TreeFailureType}  [correct syntax outside the if conditional element]
${if TreeFailureType == “Root Failure”}               [correct syntax inside for the if conditional element]
Root Failure Type:
${RootFailureType}  [correct syntax for referencing the attribute value in the if element]
This doesn't...
Type of Failure:                                       ${TreeFailureType} [correct syntax outside the if conditional element]
${if ${TreeFailureType} == “RF”}      [this is NOT correct syntax for referencing the attribute]
