Auto-populated GUIDs via NEWID() function — In web map, display a more intuitive value in the Edit tool
351
04-29-2026 12:47 PM
Status: Open
Bud
Legendary Contributor
As @MobiusSnake pointed out in https://community.esri.com/t5/arcgis-online-questions/add-guid-field-to-existing-agol-survey123-feat...
Using a custom GUID field, it’s possible to automatically populate the field with GUIDs (at the hosted feature layer level) using the NEWID() function/default value via the Admin REST API.
  "fields":
      "name" : "MyID",
      "type" : "esriFieldTypeGUID",
      "alias" : "My ID",
      "sqlType" : "sqlTypeOther",
      "length" : 38,
      "nullable" : false,
      "editable" : false,
      "domain" : null,
      "defaultValue" : "NEWID() WITH VALUES"
@Katie_Clark mentioned:
After creating the feature layer, I opened it in a web map and created a feature. At first I was worried because the interface looked like this:
But after submitting the form and checking the attribute table, the value was populated!
I was also confused when the new feature Edit window showed NEWID() as the field value, prior to saving the feature. I thought it was going to insert the literal text “NEWID()” instead of a GUID value, which isn't what I want.
This idea is to display something more intuitive in the Edit tool’s field value text box, such as the GUID value, instead of “NEWID()”.
