Hello AGOL Team,
In Map Viewer it appears there is is no filter option for "within the current year". Our organization desperately need this (as I'm sure many others do as well). For some of our production projects we have filters set to the current year, and every year we have to manually go into these web maps and update the year/date in the filter.
Please consider adding a filter for "within the current year".
In addition, please note the difference in variety of filter options between Map Viewer and even ArcGIS Dashboards. Please consider filter equivalency between the two platforms:
Thank you,
Amanda Huber
Date Only support in filtering was added in 11.3 and then with relative filters will be coming in 11.4 enterprise release. We added support for this in ArcGIS Online in the June 2024 release.
@RussRoberts Can you clarify the current status for this Idea. Here is my understanding below based on your last comment.
Thank you,
Brett
Support for
@RussRoberts Thank you for such a quick response. I'd like to point out that this ArcGIS Idea is for being able to filter to current year and not necessarily just support for relative time filters (which are still an amazing addition).
With an 11.2.1 ArcGIS Server feature service in ArcGIS Online (standardize queries enabled) I am only able to do "In the last" and "not in the last" queries for a date-time field, which does not allow me to specifically filter to the current year.
With that I'll assume that this feature is still on the horizon and will wait eagerly for its arrival.
Thank you,
Brett
@RussRoberts I just wanted to check in on this now that we've had the June update, we're still not seeing this functionality in Map Viewer for "within the current year". Is there any update on this?
Amanda Huber
